atsah
Elite Member
Op, it doesn't matter to me what stove someone buys for there heating needs but I will provide you with some information that may be useful to you and or others.
I have been heating our homes with firewood ONLY for fifty years. I have used cast stoves, steel stoves, and stoves with cats. The soapstone stoves emit heat longer than any other metal built stove on the market. It also emits a softer heat as opposed to a metal stove, what I mean by that is you can sit in the same room with the stove when it's 0F and not get driven out of the room, another thing I like about them is they have no fire brick, fire brick takes up a lot of room in the fire box.
Stoves with cats burn slower than most stoves so they heat a bit longer than say a steel stove would. The down side to them is the fire doesn't burn hot enough to keep the stove pipe clean.
A steel stove is great for quick heat but when it goes out no more heat, a cast is an in between stove that holds the heat longer than the steel but not a whole lot better IMO.
Do some research on the soapstone before you spend a pile of money, they are worth there weight in gold to me.
I live in the North Maine Woods, I know what cold is and I know how to heat a house when it's cold. Good luck in your search.
