Biggest MMM on a cab/CUT
   / Biggest MMM on a cab/CUT #3
there are logistical reasons why mid mount mowers are commonly no larger than 72". mostly it has to do with moving that much grass to a side discharge chute. after about 60", more horsepower becomes less and less useful towards fixing the problem of moving such a large volume of grass from left to right. a rear discharge gets by this problem by just allowing the cut grass to fall to the ground or exit each blade without passing over the other blades.
with my 60", i already get fairly deep windrows if i let my grass go too long between cuttings. a 72" deck would be even worse and the cut would suffer as lift is reduced by the clogging action of the side discharge challenge.
amp
   / Biggest MMM on a cab/CUT #4
The Case Farmall compacts have an 84in rear discharge model MW84R that fits the Farmall 40 & Farmall 45. New Holland also model 914A fits a few different tractor models. They are the same just different color.
