Diamondpilot
Super Star Member
- Joined
- Jan 18, 2007
- Messages
- 16,326
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
I have the 5/16" chains from HD and a 3/8" from Lowes (the Cambell brand is made in the USA, but the hooks & package from China!), but need to upgrade to an approved DOT chain. I also have 2 new ratchet style binders, that I bought from a truck supplier at $60/ea. Made in China. I can't seem to locate the US made binders.
Do binders have to have DOT stampings/tags like chains do?
Also, my skidsteer (5200 lbs) only has two tie-down points on the chassis. They are located at the center of the main body on the front and rear. When I moved it home, I ran the chains through them and bound them down, pulling to the front and rear of the trailer, like a V on either end. I also bound the buckets with straps. From my understanding of the regs, this is OK for loads less than 10,000 lbs. Can anyone confirm or deny this?
I'd rather use four chains and four seperate tie-down points on the machine. But that will require me to attach hooks on it I think. Maybe the bolt-on D rings would work.
I think you are ok for 10K and under using two appropriately rated chains. Like you said the only other thing you could do is weld on grab hooks or attach some sort of ring.
I am like you though, and feel better with 4 seperate tie downs no matter what the load weighs. I even use 4 ratchet straps when I move my riding mower. Even a 500# object like that is something I do not want coming though my rear window in a head on collision.
Chris
