R_squared
As Bird and pennwalk suggested, a belt sander works very well. I use a 3 inch, hand held belt sander with a 50 grit zirconium belt. This setup does not overheat the blade edge and touchup with a hand file is not necessary. Its easier if you remove the blades from the deck and clamp them down onto a workbench top and let the cutting edge extend out past the tabletop. Sharpening goes pretty fast as long as you use a lighter touch. This keeps the zirconium grit sharp longer. The 3 inch belt sharpens the full 3 inches and leaves a uniform beveled edge. Of course a hand file works to, but it takes a long time if your blades are real dull. Whatever you decide to go with, pick a tool that does not overheat the cutting edge. Also, forget about using that 3 dollar blade balancer, way to inconsistent.
