lutt
Platinum Member
- Joined
- Dec 9, 2010
- Messages
- 661
- Location
- Pocahontas, Arkansas
- Tractor
- Kubota ZG 22, John Deere 4200 4wd/ 420 loader, 4 wd,08 polaris 700 ranger crew
The bad thing about welding, something on a broken bolt is that if it does not come out, then you have a real problem because the welded part is going to be harder than heck.
Even if you are going to weld on it soaking it down and center punching it, will help a lot.
Drilling completely threw then putting in a penetrating oil, sometimes I would hook up the welder threw an easy out and let it heat the piece up, then when it cools off, an hour later remove it.
good luck!
I have never had that issue welding a nut on something on countless numbers of equipment that I have done over the years, more than likely, if the bolts are a large size, they wont be hard to get out anyway. LUTT
