bigtalker
There is a learning curve to the brown tree cutter. It takes a little while to understand it,s capabilities. It can be used like the traditional bush hog or you can use it in places a bush hog could never go it can take up to three passes to reach the final cut. The first pass cuts bushes ect and will lay the tree down and chip the branches off. The second cut mulches everything finer and grinds the the trunk of the tree about 50%. The third cut is where you set the cutter down on top of the dirt and chip everything including the trunk to ground level. The disc the blades are mounted to is about 1" thick and takes about 10 minutes to stop turning. It must be used correctly or ican be deadly to you or bystanders. Probably need 90-100 min. Cab is a must. Vibration can be bad. Blades come balanced from factory and must be resharpened equally to minimize vibration.
