mcfarmall
- Joined
- Oct 1, 2015
- Messages
- 1,484
- Location
- Kalamazoo, MI
- Tractor
- Kubota M5660, Farmall C, JD 260 lawn tractor
So is there a general rule of thumb for sizing a cutter to a tractor of a given horsepower? The old Farmall C can run a 5' cutter pretty well under most circumstances...loads the engine well in very tall grass but overall doesn't lug the tractor. When you consider that it is only rated at about 18 horsepower that's pretty good.
Or do you simply size the cutter based on the overall width of the tractor? If the outside of the rear tires measures 75" then go with a 7 foot (84") cutter. My father in law used to run a Frontier 7' finishing mower with ease using an antique John Deere 40.
To me, a 50 hp rated tractor should be able to turn a 7' cutter adequately.
Any thoughts? Please supply reasoning/facts with your replies.
