have_blue
Veteran Member
So if you're going the route of removing the nuts and bolts instead of cutting them off.... The stump jumper or blade carrier on this mower isn't very stout, you will have to block the bottom of the stump jumper to keep it from flexing downward when you are trying to drive the bolt down and out.
You will also need something of size that you can place on top of the bolt, that you can hit repeatedly with a sledge hammer. Helps to have someone hold it for you and take turns whacking it with the sledge hammer.
Good Luck
Right, I wouldn't want to beat on the shoulder bolt without solid backup. That would transmit a lot of shock to the shaft and gear box. I figure a short piece of 2 or 3" pipe on the concrete and against the blade near the bolt should work.
Thanks,,,
