FarmNut
Bronze Member
An all in price of $9K sounds pretty good for the tractor with those attachments. I think you will be very happy with your new toy.... I mean tool.
1*Neither 1 of these is an indicator of wether or not the tires have been filled.1*Since it looked as though the 3 point hitch was never used I just assumed that the tires were loaded since the FEL looked like it had been used a good bit.
When I checked the tires there was no fluid in them and
2*I figured that the lack of a counter weight might have been reason for the poor digging and instability. I talked to the dealer the next day and he told me to come to the dealership to get a ballast box that I could attach to the machine.
3*Once I hooked up the loaded ballast box it was an entirely different machine!
4*The ballast box made a huge difference in digging ability (traction) and stability.
1
4* No tractor should be operated with the FEL and no counter balance .
2*What do you mean might of been It certainly was why.
3*Of course it was that's no surprise.
4* I agree with you. To use the fel to its full potential you need a counter weight. If you are only going to move light material on relatively level ground where traction will not be an issue you could probably get away without having a counter weight.
Bought my first tractor 5 years ago, a BX2200 MMM FEL turf tires not filled. Traded it for a B7800 FEL Filled tires, traded that for a L3240HST filled tires and traded that to a B3200 FEL filled tires. I have 5 acres of hillside, rocky, treed land. I moved alot of rocks and dirt with the BX2200 and because it done so much I traded it to the B7800 for higher ground clearance. Sure glad I didn't know I couldn't/shouldn't move all that I did for a year on hillside property without counter weight. Sure counter weight will give more traction and stability but can't do it seems rather absolute. I really think it depends more on the load and greatest efficiency than can't or shouldn't.
I think everyone agrees that it depends on load weight and ground conditions. LBrown is often absolute with his opinion on things, but even he didn't say that you "can't do it." I notice that all of your tires have been filled since the BX2200, so even you must admit that the extra weight has its advantages. A counter weight without filled tires is accomplishing the same thing.
