poldies4
The last few times i've run my BX it seems to start pretty ugly. Today for the first time it started and quit. Lots of white smoke for the first 5-10 seconds. It lives in a dry warm barn, and only has 20 hrs on it. A while back I posted a thread about starting procedure and have not really altered mine since it was new. For some reason after starting it from cold, it sputters, and smokes before it "catches". Today it sputtered and quit after 3-4 seconds. I attempted to start it again, it sputtered and smoked for 5-10 seconds and then idled normally. I've noticed this becoming gradually worse over the last month or so. I use good fuel from a large station, and let it warm up properly, I maybe baby it too much, but this is a little bit of a concern for me. So my questions are, is this normal? I feel like my new tractor should start like a new tractor. I check my fluids before every use, and all are topped off. The tractor runs great, and once its warmed up it starts perfectly, or at least what I believe is perfect. I've always preheated for the 3-5 second per the manual, and it doesn't seem to make a difference if the throttle is at idle, half throttle(as recommended by the manual) or am I just asking a diesel engine to be like a gas engine? Maybe it's something simple? Any Ideas? Thanks in advance........
