Show images
External images have been blocked to protect you against potential spam!
I've read every thread I could find on these (TBN) boards regarding why/how a bx23 will demonstrate loss of power. Thanks to all who have shared experiences and the solutions.
I figured I'd start an new thread to both consolidate all the possible solutions, and to record my own experiences in the case none of these solutions works.
My problem seemed to start shortly after I lost the retaining pin (most here have said it's a roll pin, but my dealer assured me and handed me just a soft pin with a washer and little cotter) on the front wheel drive shaft.
I have been working on a sand dune (moving it from one part of the yard to another to accommodate the septic tank installation) and got to the point where I could traverse up and down the entire hill accept the very top which was very steep, so steep you have a hard time walking up it and remember it's all sand.
Well a Neighbor wanted some of the sand so I had switch back and forth from 4WD to 2WD (2 wd on the streeet, 4wd in the pile to scoop loads),
After doing that for a while, I felt something different, looked down on the street, and there was the front drive shaft coupler. I couldn't find what seemed like it should have been the 5-6 mm roll pin the help the universal to the shaft, but just put a regular bolt in there.
The next time I tried to climb up the big dune is when I noticed my problem. The problem is the machine shutters and bucks, but cannot generate enough power to spin the wheels burrowing the machine in the sand as it once did. On a flat surface, I can run in 2WD, 4wd Hi/Lo no problem accept when you initially mash the treadle to the floor from a stand still I can reproduce the "shutter" that is found when trying to climb the hill. The RPM's of the engine do not drop significantly, the machine just shutters and convulses violently like the wheel are spinning, but they are not. I slight improvement in this condition can be seen when loading the bucket and raising it so the weight is over the center of the tractor (obviously can't drive up a sand dune like that) .
Other things that have gone wrong:
blew the seal in one of the loader cylenders (fixed, works fine), just now blew a hole (possible rodent chew?) on one of the backhoe lines.
So Solutions I've read and tried from this wonderful Forum:
1. The Spline shaft and yoke have to line up ( not totally sure what was meant but tried to do that) As this spline shaft is not keyed, so.
2 Just replaced the oil, filter, fuel filters (both) did the 600 hydro service (after the problem started, thinking I had clogged hydro pickup screen/filter? guess not) Hydro fluid, screen engine oil all looked normal, no burnt, reasonably clean looking. replaced front axle oil ( front axle and hydro filled with SUDT)
3. treadle pedal linkage lost nut (not my problem)
4. Rim's slipping on tire (no)
5. hydro cooling fan (fine)
6. parking brake not still engaged (Although, the symptoms act like if I had the brake on and when It's shutters and can't make power at the wheels, I apply the brake to see if it gets worse, it does not really)
7. other linkages checked
8. PTO levers not engaged diverting hydro pressure away from drive train.
9. air cleaner. clogged. (cleaned it)
I hope I have each solutions mentioned and tried above, maybe I missed one or two (I hope )
I stuck my hand up into what appears to be some kinda rubber isolation coupling between the drive shaft (rear right in front of hydro fan) and it feel kinda crumbly in there, like it's not a solid peice, wonder if that's not as it should be?
I am pretty much at the end, I feel maybe the Hydro drive unit is somehow cooked, I am hoping not, but I have not found any other possible cause.
Once I put that hydro line back on, When I get that line back on there, and I find it doing this same shuttering and shuttering, I will have to submit to the vagary of the dealer
Hope someone can help?
