BX running hot
   / BX running hot #11
There are gaps at the bottom of the screen-holder , hence it's the
lower middle that blocks as the fan sucks it against the rad. I stuffed
a piece of foam stick ( about 12 - 14" ) at the bottom of the
rad guide , but it's far from perfect and still needs clearing every
10 hours . It's mainly a MMM caused problem due to cutting right
below the rad. The round case screen does it's job , since there's
nothing on the battery etc. I really do think the rad is too small and
should be the size from the B##20's ....................:mad:
   / BX running hot #12
below the rad.
What I experience is different. I get far more chaff that's sucked in and clogs everything up when I use my brush hog on dried out wild oats. The tractor is moving forward while the rough cutter is behind the tractor with a rear discharge. The chaff is so light that it just stays in the air. When I'm mowing with a tailwind, it just pushes the chaff forward where it is sucked into the outer screen. If there is no wind, it stays in the air, and every time I make a 180, I'm just driving right back into the still floating debris from the previous pass. If I don't clean the outer screen every 4 min. and clean the inner screen and the radiator face every 30 min., I wind up redlining. This constant cleaning gets to be a PITA, but it's better than blowing a gasket or warping some engine component.
When I cut live grass with the MMM, it is mulched and falls to the ground. If it is an early season cut, it will not all mulch and I get side discharge. I only use the MMM on green grass that does not float in the air. In any case, I never have a radiator clogging problem from the MMM.
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A50397)
Morooka MST 660VD...
Vermeer BC1800A Chipper (A48837)
Vermeer BC1800A...
2016 VOLVO DD25B DBL DRUM ROLLER (A50458)
2016 VOLVO DD25B...
2003 International 4200 Crew Cab Landscape Truck, VIN # 1HTMPAFM13H594121 (A48836)
2003 International...
UNUSED KJ 20' X 30' METAL GARAGE (A50460)
UNUSED KJ 20' X...
1999 Volvo VN Truck, VIN # 4VG7BBRFXXN772814 (A48836)
1999 Volvo VN...
