Volfandt
Veteran Member
Re: BX2230, w/ 60\" mmm Mower Review
I'd say your cut will improve when you mow when it's drier. Your BX is over 1k lbs heavier than your L130 and wet grass will mash down and not spring back up as quickly. You'll probably notice a better finish a day or so after the mow also. (the tire lines will disappear). I'm very happy with my BX23's finish cut. That power steering coupled w/the HST just can't be beat /forums/images/graemlins/grin.gif
The are tiimes when I use my cyclone rake to vaccum up the clippings and it connects to my BX23 via the 3PH. I also had a problem with the hitch dropping too low when I lowered the MMM so I starting useing an old trick I learned back when I ran a bush hog behind my old TE20 and that is a "check chain".
Basically make a loop of chain and loop one end up at where the top link connects to the tractor and the other end around where the weightbox connects to the 3ph. You may have to make some kind of hook to center it at the bottom of the weightbox. Adjust the loop to where the chain will go taught once the weightbox drops down to where you want it to stay. Once taught it won;t drop any further. It won't interfere with the raising or lowering of the MMM or weightbox either.
Good luck
Volfandt
Good luck
Volfandt
