Volfandt
Veteran Member
great post lp333, this may open some otherwise closed doors to us.
I much more enjoy the "nut's & bolts" much better than the "spec's" anyday
In a past life I worked directly with sales and marketing and one of the main goals of a particular marketing division is to gain an edge (or advantage) over it's competition. Most times the resulting edge isn't an out and out misrepresentation, it's merely taking a different avenue to arrive at the same conclusion. The conclusion is probably not false, it's just measured or determined by a different formula at a different place. I used to call it imaginative fabrication
This is why I snicker at those that take the "spec's" as gospel and not use the "real world" application of a product as a better measureing stick.
Whats likely to be more accurate, the spec indicateing a 460lb lifting limit on the FEL or actually seeing and/or working said FEL easily with nearly 600lbs of material?
Theres just NO WAY a particular product in a specific class is going to be "that much" better than comparable competing models, the competition is just too tight to allow one model to "run away" with it all, with the loan exception like Kubota did when it "invented" the subcut line. Course it wasn't long for it's competiton to catchup.
Anyways, I do have a WSM on the D905 but not the D902 and it would be interesting for those of us to post various specs between 'em to see if we can figure out where that additional 1 hp comes from. Could be we could easily squeeze out alittle mo-power out of both with sacrifying durability
I'd really like to increase the GPM more in my BX23 but not at the cost of prematurely wearing out various hydraulic assemblies.
Course time will tell and in a tractor's time frame, it can take decades to get that "great" reputation.
Sometimes this is not a bad thing. Kubota seems to have stepped up to correct the 1st release issues that plagued the new BX series and when I visit the various different dealers to check out all the brands out there, plastic (or composite) materials are integrated into even the premium large tractors as well as the CUTS & SCUTs. In some cases the engines have been scaled back from 4 to 3 cylinder and alot of users have commented on the 3 cylinder diesels being smoother and even more powerful, over a comparable 4 cylinder. Some say the composite "skins" of these new tractors take more abuse without showing the results better than metal, i.e. no pot marks and/or dents.This would fall in line with Kubota's ongoing efforts to cut the production costs for the popular BX units.
