1*Exactly the reason I leave my BX23 set up with the FEL BH and 60'' MMM on it just like it was when I got it 3 years ago.
2*Have done all of this with my BX23 with all 3 attachments on it at the same time.
Absolutely no issues or problems using it set up that way.
3*I have a BX 1500 with a 48'' rear tiller and 60'' front blade for that and grading and landscaping task.
Here again I don't have to do any attachment switching.
4*I prefer leaving the mmm on doing such task.
Works fine for me and I don't have to fool around playing musical attachments.
In my book that's the only way to fly!
5*I've never had a ground clearance issue with the rig.
6*I've never felt a thing doing that on the BX23.
7*no way would I want to put myself in the position of having to constantly install and remove the Mower and BH over and over again and again.
Thankfully The MMM saves me all that hassle.
I can only see one advantage that a rear 3 point finish mower or brush hog has over a MMM.
You can back them out over banks and ditches to trim them.
8* 48'' Max.
Woods land pride and king kutter.
Should be able to find good used for about have the cost of new.
Exmple I just paid $1450 for a new MMM.
I have a good used one I'd take $725 for.
9*A pull behind is hooked to the trailer hitch and is towed like any trailer would be.
They are powered by their own engine rather than from the tractor.
A 3 point mower is attached to the tractors 3 point hitch and is powered from the tractors rear power take off.
== L B ==
JWK1 said:
I'm seriously considering going with the back mount type rotary mower.
1*The reason for this is that I fully anticipate needing the BH and FEL for work in between most mowings.
2* I've got some stumps, ground lvening, driveway trench digging for drainage, etc. The list goes on and on.
3*garden bed digging,
4*The point being that I don't want a MMM on while I'm doing all this .
5*if nothing more than the lack of ground clearance.
6*It would be a real pain negotiating through the woods or brush with that thing on.
7*If you worked like this in between most mowings, would you go with a rotary rather than the MMM?
8*What is the recommended size rotary for the BX24?
Any make recommended other than Kubota?
Are used readily available and worth it?
9* I also don't understand the difference between a pull behind and a 3 pt mower.
