Ken45101
Elite Member
- Joined
- Feb 14, 2009
- Messages
- 3,655
- Location
- southern Ohio
- Tractor
- Kubota M5040, M9540, B21 TLB, B2710, RTV900, JD 325 Skid steer, KX-121-3 mini excavator
Someone mentioned skidding down a hill with useless brakes. I haven't done this, as my slopes are not long enough runs to get into a runaway situation, but if your run is that long, you might trail the bh with the boom straight and the bucket curled, teeth down. If you loose traction and start to slide, be ready to pull the lever and impale the bh teeth to get some drag. You can also drop the FEL and let the bottom scrape. I would do the bh first though in order to have the resistance in back of the tractor rather than in front of it.
The hill I slid down was only about 60'. It doesn't matter how long the hill is, once you lose control, you've lost it and it's hard to regain it unless the slope flattens out. Again, that only happened when I had the tractor in 2wd, going forward down the hill. Because the weight of the tractor is above ground level, when you are facing downhill, weight transfers off the rear wheels (reducing rear traction) and puts it on the front wheels which do not have braking in 2wd.
I have never experienced a problem with the backhoe sliding (it is always in 4wd), but I would go with dropping the loader bucket over trying to dig in with the bh teeth (I'm just speculating here). If you drop the bh bucket, you are removing weight from the rear axle, letting it lift. If you drop the loader bucket, you are unloading the weight on the front axle and giving more weight to the rear axle for braking, and more stability with the wider FEL bucket.
If you have a problem, it's going to be from front weight, not rear weight IMO. I'd rather get that heavy front bucket on the ground. Just my thinking, your results may vary.
Ken
