calculate bucket pryout force.
   / calculate bucket pryout force. #21
rbargeron said:
The biggest "pryout" force happens when the back/bottom of the bucket is pressing against the ground and becomes the pivot point - like when you push with the boom while curling the bucket to break roots around a stump. The discussion above will give the force available from the bucket's curl linkage - then boom force can be added to the mix to get the max total force available at the teeth. The exact answer is usually not as important as whether or not it is enough ;)
You are absolutely right and I have seen cylinders bend in that situation on an under designed hoe. Not that I don稚 use the same technique.
MarkV
2017 Ford F550 Altec Bucket Truck (A52377)
2017 Ford F550...
2018 BOBCAT T550 SKID STEER (A52706)
2018 BOBCAT T550...
2004 INTERNATIONAL PAYSTAR 5600I DAYCAB (A55745)
2004 INTERNATIONAL...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A55302)
GMC 3500 Extended...
