Chilly807
Elite Member
With my system the make-up water supply serves two functions. It replaces any water that is "lost" for whatever reason. Secondly, it maintains the system pressure at about 15 psi.
I don't have a traditional boiler, but a geo-thermal heat pump. Having said that, the "heated water" side of the system is pretty much the same regardless of what type of heat source you use. The temperature and flow rates may vary from type to type, but the components are generally the same.
I use in-floor piping for a heat exchanger, and individual zone pumps to circulate the water, plus a central circ pump to move water through the heat pump and storage tank when it's running.
The Spirovent is mounted at the top of the system, which is where trapped air will go as it circulates. I've never had any issues with trapped air so it must be working. My water temp is relatively low (about 90* F max) by design, although it's adjusted by the outdoor temperature sensor as the outside temp drops or rises.
If you're getting too high a water temp through localized heating, the water can begin to boil, which will generate steam in the system and cause problems too. It may be as simple as increasing the water pressure slightly to increase the boiling point or boosting the pump flow through the heating coils to improve heat transfer.
All my pumps are variable flow (manually set) to fine tune the flow rates as required. In general, your zone pumps (if you have them) should be pressure fed from the main circ pump, otherwise they will cavitate if the flow rate through the main pump isn't high enough. i.e. if you have two zone pumps both demanding water at 2 gpm, and your main pump is supplying it at 3 gpm you have a problem. A single circ pump and several zone valves will eliminate that problem, but there are advantages to setting it up either way.
Sean
Sean
