Tractor Seabee
Elite Member
- Joined
- Oct 5, 2011
- Messages
- 3,900
- Tractor
- Kubota BX25
I am trying to plan for adding a concrete pad to my driveway for extra parking and my sons basketball goal.. Is there a way I can estimate the cost myself so I am prepared when I do call for estimates?
Also is there prep work that I can do myself to save some money like digging, framing etc? Are there people that will just come in pour and spread?
Wade
Wade,
There are some good things said here but some take with a grain of salt. I have been a member of the American Concrete Institute (they do research and set all the standards for concrete construction) and a concrete inspector. What I will tell you is the subject of many good ole boy rants as nonsense, but it is based on lots of research and testing. The following is only based on an outside driveway application.
All concrete does not crack. There are many variables that can cause it to crack but most can be controlled.
Question: what type of soil do you have? Answers: If it is sandy/rocky you will not need any gravel under it. Be sure to strip off all top soil first, then grade relatively smooth the thickness you want the slab. If you are building on something other than sandy/rocky soil strip out another 3-4" for the gravel subgrade you have to put under the slab. Use 3/4" minus crushed gravel, rake it out even and tamp it down with a plate compactor or a hand tamper (up to you which).
Build your form from 2 X 4s using double head nails. Splice all joints with short pieces. Line it up with existing and square it up on the end. drive a stake every 4 feet. Metal stakes; drive below the top of form, wood stakes; you can cut flush after setting height. Start at ajoining slabs and set form flush with the top and nail with one nail at each location. At each other corner nail to the stake at the grade you want to make it. If you are a little high thats OK and scrape down if you need to lower it some. Set a string line at the top to make sure you nail to each stake and keep the top in lone. After it is all nailed and graded put the second nail in each stake.
Check the grade of the subgrade to make sure it is at least 3.5" or more every where and then water down good with a sprinkler.
Find that guy that will place the concrete, screed it, float it and broom it. If you want a gravel finish he will take care of that also. You do not want to tackle this unless you are a pro and have the proper equipment.
Forget about wire mesh, rebar, and mesh hooks. Think about the physics involved, try to stand on that wire mesh and hook it and pull up on it. I defy you to budge it. So, that is a waste of money. Wire mesh is of no value if it is not in the right place in concrete. Buy heavily fibered concrete mix and you will be fine.
Work with your finisher and order the concrete, 4000# fibered 3/4' aggregate or pea gravel if that is the finish you want. Depending on local conditions he will know if any other additives are needed. When the concrete gets there stand back and let him do it. Warning! discuss this before hand; do not add water, get the mix right for the conditions.
He will consolidate, screed and bull float. Discuss this before hand also, he will cut in the control joints as soon as he can get on it. His cutting trowel needs to be at least 1.5 " deep. Match spacing of existing and if more than 14' any direction cut it in half.
Now! its is all up to you, depending on weather, keep it wet and shaded from the sun for several days.
Lots of luck, and no cracks. If your finisher wont agree to the above procedures, find a new one.
Ron
