KYErik
Platinum Member
- Joined
- Dec 2, 2005
- Messages
- 893
- Location
- South central IL
- Tractor
- 1977 AC 7000, 1980 JD 2840, 1963 Case 930, 1963 Ford 4000, 1943 Case SC, Case 530CK backhoe
Here's a random cellulose question- when they spray the cellulose onto the wall between studs (before you put up the drywall) what makes it stick there (and not just fall out)?
Is it wet (with water) or is it some special non drying chemical or glue that makes it stick together? I would think that if it was wet (with water) the dampness of it would cause the studs to mold and rot when the drywall was installed and trapped all of the moisture in the stud cavity.
I used cellulose in my garage attic and I am very impressed with how easy it was to blow in and at how well it works.
