Do you guys think this is basically a DIY fixer or is it something I should bring to a dealer? I really think I can tackle this on my own. I'm handy enough for this project I would think. Why can't I find & order parts directly from Rad-Tech?
I bent pretty bad the upper manual chute rotation handle & it's about to break into two from continually trying to straighten it out. I guess I have to go only to a dealer for parts? That s_cks in my opinion. I can order parts for all my other implements online execpt for my Blizzard B64 it seems.
Hold up there:
No worries, fortunately these brats are dumb enough to fix on your back in 2 feet of snow in the dark with a flash light been there done that with chain drives using much larger chain.
About your handle,
just go to a welding shop with it and buy a piece of thick walled tubular steel to slide over the handle after it is split and slide it over on part of it before you weld the ends back together and then weld the tube over the broken areaon the tube ends.
Take your time and if possible buy two boxes of 60 chain that is cotter keyed- I will explain why;
IF and only if the pins were assembled in line with the pin holes in line that will make your job so much easier especially when its dark and cold.
Be sure to buy a separate bag of cotter keys that are the same size as the cotter keys used on the roller chain AND-
buy cotter keys that are 4-6 times as long as the keys used in the chain-
the reason why is because the cotter pins are longer and will pass through the paired holes in one pass IF they are in line and then you can simply roll the pin ends back with ease with two pairs of needle nose pliers for the long cotter keys if the roller chain has straight pin holes that is a blessing.
If the pins are not aligned no worries as you can simply fold the key halves back and your done and you have more pin to work with.
Be sure to buy a small bottle of BLUE loc-tite for the bolts used to secure the chain guards.
leon
