vtsnowedin
Elite Member
That won't work well except on perfectly level ground. When you crest a hill and start down the plow will be held in the plane the tractor is on until the rear wheels get to the new grade and leave a patch of thick snow just where you least want it. Coming to the bottom of a hill from a flat the plow will get to the ground first and follow it up like it should, assuming you haven't mounted it ridged so it can't, but then come back up to your skim position when the whole tractor gets on the new grade. The whole effect will look like a bad haircut. scalped here missed there. Your trying to use it like a bulldozer or grader which are meant to fill in lows and shave highs but even those are put into float when they need to follow the ground.Raising the loader, and hence the plow, off the surface,(ground/grade/snow) puts the weight on the front tires and allows them to have better traction than just placing the plow on the surface which reduces traction at the front tires. The concept is to PUSH snow, not to scrape down to dirt/asphalt, etc. In order to push snow one does not need to have the snowblade edge scrape clean the surface- it just needs to skim it.
Talons, sure- for what money?
Tires loaded, yes.
New Talons are not cheap. I saw one site that had them in my size 13.9 x 28 for about $1100 a pair. I got mine of Craigslist for $350 but had to lengthen them to fit. They work so well though I think even new ones are well worth it.
