Chilly807
Elite Member
Weird.
So the radiator cap just vents outside?
Yeah.. if you fill it to the top of the filler neck it drools about half a cup of AF on the ground when it heats up to operating temperature. After that it's fine.
Sean
Weird.
Does the HST have an oil cooler setting in front of the radiator and gear does not? If so, the oil cooler would be adding more heat to the radiator (warmer air coming through the fins) so more expansion room is needed.Interesting that the L3400 DT (gear) has no recovery tank, while the HST version does... I have no idea why they are different though.
Sean
Chilly807 said:Yeah.. if you fill it to the top of the filler neck it drools about half a cup of AF on the ground when it heats up to operating temperature. After that it's fine.
Sean
NevadaMOGuy said:So when it cools down it could suck air in?
What a crazy design.
I think there should be a drain on the block.
WilliamBos said:The drain on our 1635 is lower than the block, so everything gets drained, cab included.
There will still be some in the water jackets. The water jackets go lower than the water pump.
WilliamBos said:Not enough to loose sleep over. That is why it gets changed yearly as per the manual.
94BULLITT said:There could be a 1/2 gallon in there plus alot of the time there is alot of sediment/trash that comes out of the block.
