Valkyrie Rider
I'm approaching 50hrs on my 2610HST and I'm a little confused about the HST and hydraulic fluid change. I have ordered the filter kit that has the oil, fuel, HST, hydraulic, and air filter. Various posts on TBN seem to indicate that the HST and hydraulic fluids are separate, but the manual only covers transmission fluid and filter. Are there separate drains for the HST and hydraulics? Where are the drain bolt and fill port for the hydraulics and what is the capacity? I have 7.5gal of Mobilfluid 424 to cover the 5.8gal of transmisison fluid per the manual, but now I'm not sure I have enough if the hydraulics are separate.
Thanks for the info!
The fluid is the same for the HST and hydraulic. Drain and fill from common sump, not different locations. Mine held <6 gallons when I changed the fluid and filters
Fill for hydraulic is the dipstick in the 3point ***** area under the gas tank.
The drain is on the bottom of transaxle.
I also changed the front axle fluid at the 50 hour mark.
