DanSullivan
I have an '88 JD 2755 with synchro trans and manual clutch. Shaft does not stop completely when clutch is depressed. I must go to low idle and select gear 4/8 before selecting range, or it will grind before engaging range. Gear 4/8 is the only gear that will engage without grinding. Clutch pedal free travel is adjusted to 1 inch. Anything else I can do before separating housing?
