Thanks all. I'm thinking a smaller 4wd will be fine. We never have snow so that's not a concern. No need for a cab or anything like that. This will mainly be a toy for me. I'll use it to maintain trails for my kids motorcycles, bush hog a couple of acres to shoot skeet, etc. It certainly won't get used every day. I'll get to looking.
smaller tractor with the extras....
or larger tractor with extreme basics...
those extras can really pay for themselves.....
AG / R1 tires. would be better for mud like conditions, granted AG tires will more likely tear up the finish lawn around the house though.
TNT (top and tilt) hyd cylinders for 3pt hitch. can really make a difference, being able to adjust angle left to right and back and forward of a scrapper blade, box blade, land plane, even a bush hog. most tractors just come with a turn buckle you need to hop off of tractor and then adjust the top link and a side link to adjust the 3pt hitch implement, but replacing turn buckles with hyd cylinders. can make jobs quicker and put on a better professional look better, once you get experience under your belt.
going for higher up "work lights" rear work light advisable. makes for dealing with hooking/unhooking implements, and maybe another hour or 2 of work before sun completely goes down on you, during spring/fall times of the year.
if there is an option for larger alternator, i might advise getting it, more so if ya plan to get a couple extra work lights on tractor and perhaps thought of adding a winch to the tractor (it helps)
with trees ya got trees that are down, or getting stuck, adding a good rated winch to tractor can always make things easier pull logs out of the woods or getting yourself unstuck, without anyone else the wiser.
FEL (front end loader) with general heavy duty bucket. (not the cheaper wood chip only buckets), would advise a tooth bar for cutting edge, if you plan on digging, 4x4 or MFWD can also help when digging with FEL. granted fel is not the best thing to dig with but it is there.
if ya dealing with a bunch of trees that you want to take down over time or ya chop fire wood. it may be worth while to look at a unit with a backhoe (a 3pt hitch with sub frame advised) to get rid of them ugly stumps.
kinda of a bad time of the year, but during spring/summer/fall, the forum last couple years tends to be hoping with huge amounts of little extras folks end up adding to there tractor....
chain hooks to the FEL bucket, places to hang 5 gallon buckets, or hooks to hold chains. lights, adding hyd cylinders or gauge wheels to various 3pt implements to make 3pt implement a tad more easier to set to depth or angle better. perhaps going with telescopic lower arm links for 3pt hitch, or going with some sort of quick attach for 3pt hitch or for the FEL.
pallet forks, rear scrapper blade, box blade, land plane, 4in1 bucket, grapple for FEL. bush hog (rotatory cutter), post hole digger / auger. various racks.
figure out what might work best for you.
