ducati996
Banned
MessickFarmEqu said:Here is another tidbit I learned today. Browse on over to deere.com. In Ag tractor world all anyone cares about is PTO HP. For years tractors have been classed by their power to the ground, this is how its always been. Recently Deere changed to listing all their models by engine HP. Part of the reason for this is because the driveline efficency of other companies is improving at a rate much faster than Deere. Other companies are doing more with less HP than Deere is achieving. So, the quick fix here is just to start dropping your PTO HP spec where convienant, and substitute Engine HP instead.
Messick,
I actually notice on Kubota's site that and specifically on the BX Sub-Cut series (BX24 & 2350) that they are full CAT I 3pts. I do believe that is not true at all...
I also wonder why in the competive comparison listing on the B2630 which basically matches the Deere in hydrolic flow, PSI, HP, weight, size, somehow has a higher 3pt lift rating along with the FEL rating than Deere's 2520 series ? but they sure look equally matched in all areas, and when machines look equal on spec they usually are, at least from my experience
I guess I could conclude either Deeres spec's are too conservative (which I know they are from real ownership-) or Kubotas specs are off, or indeed Kubota is accurate and Deeres is off. I dunno what the actual answer is on that is but it makes me wonder out loud.
Duc
