hosspuller
Veteran Member
- Joined
- Oct 9, 2008
- Messages
- 1,784
- Location
- Piedmont Triad, NC
- Tractor
- Didn't intend to have a Deere fleet - it just happened 310C, F915,102, 5200 & 5065E
Folks,
Long story, short. A subpanel in the house has had water intrusion at some point and now it has corrosion. What should I do, if anything, to fix this.
Here's my suggestion ... Replace the panel. Install it on the wall with a space between the wall and the panel to fix the water intrusion problem. Separate the neutrals & grounds to comply with code. Finally, replace the breakers when money allows. you could do this a few breakers at a time. I would be concerned about the breaker internals being degraded like the other connections. You really want the breakers to work when needed... Bad things happen quickly if they don't
