cowboydoc
Super Member
- Joined
- Dec 23, 2000
- Messages
- 6,725
- Tractor
- JD 8320 MFWD, JD 6415 MFWD, FEL, and cab, John Deere MFWD 4600, John Deere 4020, John Deere 4430, John Deere 455 mower, Deutz, and Gehl 4610 perkins skidsteer
Dan,
Yes to all your questions. Just remember though you can't feed a horse alot of grain at once or they will founder. You can only feed them 5 lbs. at the most so you will have to feed grain daily. As far as hay you may get into trouble putting out a round bale for one horse. Problem is that one horse won't go through a round bale very fast and they are prone to mold and that causes colic. But if you got a round bale feeder and put it in your lean to you would be fine.
As far as winter goes yes your horse will do just fine and without a blanket! A good three sided lean to will be fine. Just make sure that you line the sides up about 3 or 4 foot so they don't kick through if you make it out of tin.
Electric fencing will be just fine. I wouldn't use barb wire though.
As far as a friend just get a goat. Doesn't sound like you have anything there to worry about the goat getting into.
Finally don't even worry about the land. As long as there is no wire or anything out there your will do just fine. They don't need pasture if you're feeding good hay and grain. Your horse will eat what grass is there and chew on other things.
Good luck.
Good luck.
