/ Craftsman Lawn Tractor Abuse/Don't Take a Knife to a Gun Fight/I DO Need a Brush Hog!
Hi Prokop...this is my second Craftsman 42"...first one I got with the property and was about 20 years old. I finally decided I needed a new one. This one is 6-7 years old...25HP V twin BS...I was really worried about the engine as I mowed my field as the weeds were tall (3'-4' in some spots), thick and still very green. I had to really take it easy and seemed like I could only "bite" about 6" per pass. Motor sounded pretty good and I checked oil a couple of times...all seems to have survived.
I did break the deck drive belt and had to pull it out of a drainage ditch with my truck (little worried I may have bent something then)...also the discharge "deflector" is now fully ripped off...since out in the country it seems to allow the discharge to spread out a bit more. ALso, yesterday I quickly re-mowed the dead, dry hay and weeds. It was very dry and was a windy day so it dispersed it pretty well. I may go out today and do the same with what I cut yesterday.
Do you brush hog your property now?...or use a heavier duty Kubota deck mower? I am curious if I brush hogged...would I still be tempted to do a "finishing" pass with a rider or other deck mower? I DO like the look now that I am done.
IF I had a CUT I would "consult" with neighbors who farm and hay their fields to determine what I might do the smooth out the field and eliminate or at least begin to reduce the amount of weeds vs hay. The field is on 20 acres across the highway from our home in 60 acres of woods. There are times I think about building a garage/barn on the 20 acres and would like to eventually either build a home there or sell it in 2 10 acres home sites as we will eventually move toward kids/city as we get older (now 63). Thus, I want to keep the open part of the 20 acres nice...and even improve the street appeal.
I really DO respect what my $1500 Craftsman does for me. BTW...I purchased a new deck a few years ago b4 I "learned" about replacing the spindles...I think it was about $300+...not too bad as a cost every 3-4 years if that is necessary. I have since repaired the first deck and now have a spare...may need to put the spare into action after the last few days
I need to start looking more seriously for a CUT maybe...
35-40HP
4 Wheel Drive
PS
Used Probably
JD/Kubota/NH/?...dealers within 50 miles for service needs
Low hours
Could look new if low hours units are as expensive vs new as they appear.
Probably a new thread...
Thanks...TMR
35-40HP
4 Wheel Drive
PS
Used Probably
Low hours
Thanks...TMR
I am with you bro, before the Kubota came along I used Craftsman 42" lawn tractor to cut grass on our property. That poor thing had to be welded up every week, I don't even remember how many of those stupid alum spindle housing I replaced.
Front axle was stamped metal and I had the luck to be able to replace it with a forged one from older mower - that was after the original got bend and the tractor would go straight and to the left but never to the right
The cutting deck was so beaten up I had to reinforce it with trusses and much much more.
The land was just too rough for that little thing.
