vtsnowedin
Elite Member
Here is a page from the online manual for the 6330. the note at top left is what I was looking for.
Permissible Front Axle Load in Relation to Tires (Operation with Front Loader)
The values quoted here apply only for travel speeds up to 8 km/h (5 mph). Max. permissible front tread width with front loader is 1.80 m (71 in.).
On leaving the factory, tractors may be equipped with the following tires:
Tires
SRI*
6230 tractors
6330 tractors
6430 tractors
12.4R24... 119A8 550 mm (21.7 in.) 4080 kg (8995 lb) 4080 kg (8995 lb) 4080 kg (8995 lb)
13.6R24... 121A8 575 mm (22.6 in.) 4350 kg (9590 lb) 4350 kg (9590 lb) 4350 kg (9590 lb)
128A8 5400 kg (11905 lb) 5400 kg (11905 lb) 5400 kg (11905 lb)
13.6-24... 10PR 575 mm (22.6 in.) 5500 kg (12125 lb) 5800 kg (12785 lb) 5800 kg (12785 lb)
14.9R24... 126A8 600 mm (23.6 in.) 5100 kg (11240 lb) 5100 kg (11240 lb) 5100 kg (11240 lb)
16.9R24... 134A8 625 mm (24.6 in.) 5500 kg (12125 lb) 5800 kg (12785 lb) 5800 kg (12785 lb)
11.2R28... 116A8 575 mm (22.6 in.) 3750 kg (8265 lb) 3750 kg (8265 lb) 3750 kg (8265 lb)
12.4R28... 121A8 600 mm (23.6 in.) 4350 kg (9590 lb) 4350 kg (9590 lb) 4350 kg (9590 lb)
13.6R28... 123A8 625 mm (24.6 in.) 4650 kg (10250 lb) 4650 kg (10250 lb) 4650 kg (10250 lb)
14.9R28... 128A8 650 mm (25.6 in.) 5400 kg (11905 lb) 5400 kg (11905 lb) 5400 kg (11905 lb)
320/85R24... 122A8 550 mm (21.7 in.) 4500 kg (9920 lb) 4500 kg (9920 lb) 4500 kg (9920 lb)
340/85R24... 125A8 575 mm (22.6 in.) 4950 kg (10910 lb) 4950 kg (10910 lb) 4950 kg (10910 lb)
380/70R24... 125A8 575 mm (22.6 in.) 4950 kg (10910 lb) 4950 kg (10910 lb) 4950 kg (10910 lb)
380/85R24... 131A8 600 mm (23.6 in.) 5500 kg (12125 lb) 5800 kg (12785 lb) 5800 kg (12785 lb)
420/70R24... 130A8 600 mm (23.6 in.) 5500 kg (12125 lb) 5700 kg (12565 lb) 5700 kg (12565 lb)
420/85R24... 137A8 625 mm (24.6 in.) 5500 kg (12125 lb) 5800 kg (12785 lb) 5800 kg (12785 lb)
440/65R24... 122A8 575 mm (22.6 in.) 4500 kg (9920 lb) 4500 kg (9920 lb) 4500 kg (9920 lb)
480/65R24... 127A8 600 mm (23.6 in.) 5250 kg (11575 lb) 5250 kg (11575 lb) 5250 kg (11575 lb)
480/70R24... 138A8 625 mm (24.6 in.) 5500 kg (12125 lb) 5800 kg (12785 lb) 5800 kg (12785 lb)
540/65R24... 135A8 625 mm (24.6 in.) 5500 kg (12125 lb) 5800 kg (12785 lb) 5800 kg (12785 lb)
280/85R28... 118A8 575 mm (22.6 in.) 3960 kg (8730 lb) 3960 kg (8730 lb) 3960 kg (8730 lb)
320/85R28... 124A8 600 mm (23.6 in.) 4800 kg (10580 lb) 4800 kg (10580 lb) 4800 kg (10580 lb)
340/85R28... 127A8 625 mm (24.6 in.) 5250 kg (11575 lb) 5250 kg (11575 lb) 5250 kg (11575 lb)
380/70R28... 127A8 625 mm (24.6 in.) 5250 kg (11575 lb) 5250 kg (11575 lb) 5250 kg (11575 lb)
380/85R28... 133A8 650 mm (25.6 in.) 5500 kg (12125 lb) 5800 kg (12785 lb) 5800 kg (12785 lb)
420/70R28... 133A8 650 mm (25.6 in.) 5500 kg (12125 lb) 5800 kg (12785 lb) 5800 kg (12785 lb)
139A8 5500 kg (12125 lb) 5800 kg (12785 lb) 5800 kg (12785 lb)
480/65R28... 129A8 650 mm (25.6 in.) 5500 kg (12125 lb) 5550 kg (12235 lb) 5550 kg (12235 lb)
VF 520/60R38... 138A8 650 mm (25.6 in.) 5500 kg (12125 lb) 5800 kg (12785 lb) 5800 kg (12785 lb)
138D
* Speed/radius index
OU12401,0001B64 -19-11FEB09-1/1
OMAL171299: Premium Tractors 6230, 6330 and 6430, Block File: OU12401_0001B64_19_11FEB09.htm
Tires
SRI*
6230 tractors
6330 tractors
6430 tractors
138D
