Next pop-quiz... This one also puzzles me. Let's call this 7 1/2" long and 7/8" (outside diameter) on the tube.
Look FAR left, there is a screw on cap. Let's take it off. (comes right off even after 30 years in the dirt)
Here's the cap in front.... it's a cover. Look at the 'knob' on the far left. It reminds me of a nose sprayer AND it's spring loaded. Let's look at the tip a bit closer...
Here's the tip. You can just see the spring under it (that is still intact) allowing the tip to compress in just a bit and then spring back out. The tip does NOT lock in any way, simply spring loaded.
Let's go to the next threaded piece, roughly halfway down.
On the backside of the left piece....is essentially, a piece of material, felt, sponge.... SOMETHING. I'd liken it to maybe a spy movie where the good (or bad?) guy has some ether hidden in this easy to hide tube assembly (maybe if you slide it up your hiney) The white part, soaked in ether so when they capture you they can unscrew the top, have you hold still while sticking the plunger into your nostrels to administer said ether into your lungs. Ok, I don't think that works very well but it DOES strike me as some delivery tool and this is the storage of said whatever is being delivered. You can see an attachment/holder piece at the base of the white part. This whole assembly moves against the spring located in the very top.
However, let's now look at the far RIGHT piece.....the handle. It ALSO has a spring in it. I don't really know why since everything on the left seems operational on its own. Also, on the far far right, is yet another threaded cap (this one is currently stuck). Could this be where the spys load this up with either or maybe moonshine?
This is some kind of metal that has been chromed. I can make out the name "Trilite" on it. I can't yet make out the word next to Trilite. It is also made in England
FOUND IT! Trilite Inhaler
