radioman
Super Member
hold on -- didn't you say winter storage? Do you mean your diesel engine equipment you want to store for winter will not be used till warmer weather? If this is the case - then no gelling issues will be concerned with. diesel will always revert back to ungelled state when temps rises above the waxing point. If there is an off chance that you will use your diesel equipment when temps is lower then cloud point of diesel. What is the cloud point ? well -- it depends on the blend you have in your tank at the moment. could be 40 F degrees or low as -10 F.
If you will use your diesel then put in additives.
