BuckeyeFarmer1994
- Joined
- Sep 4, 2009
- Messages
- 20
- Location
- Southern Ohio
- Tractor
- 1984 John Deere 2750, 1976 JD 2240, 1951 Ford 8N, 1955 Ford 650
It is possible that the distributor shaft itself broke, but if so it would seem that you could turn the rotor by hand........was the oil pump still attached when you tried spinning the rotor?
by the way - that engine (134 ci) is timed via timing gears, as opposed to a chain, and the distributor gear does run off of the cam shaft.
