Here in NW WI I use loader turf tires. Older JD 855, 4x4.
After the driveway (gravel) has a snow pack and freezes over I use 2 link ladder chains. I think a lot op people use chains for gravel drive snow removal regardless of the tires they have. And I have read many will use chains on tar as well as concrete. Otherwise I have skidded timber, pulled a sub soil tool, and run all manor of normal implements with no problems. Moved several truck load of gravel, and maintain a long drive. Also mow about 5 acres with the MMM deck.
if its a lil wet.turf tires will spin bad in snow,but thats my opion (Texas ?)
I'm know there are parts of N Texas that get some snow periodically. Been there, seen that. But not like here in WI.
I guess I wouldn't spend the extra money unless I found a good reason to do so. Then you can buy the extra tires and wheels to go with them for your specific needs.
Good luck
