sandman2234
Super Member
- Joined
- Dec 4, 2005
- Messages
- 5,853
- Location
- Jacksonville, Florida
- Tractor
- JD2555 and a few Allis Chalmers and now one Kubota
I was acused of being able to tear up a steel ball bearing with a rubber mallet. With that in mind, realize that the only problem I have had with my box blade is bending the pins and the part where they mount. The second picture of the Woods XB72 has the lift arms centered between two brackets, instead of a pin extending from one side. That is what I intend to do with my box blade, to prevent bending the pins and their mounting bracket. The pin going thru two brackets is superior to the pin coming out of a single side.
However, you have to make sure the boxblade fits, as you can't turn the pins around to the inside when it is the other way.
Buy the heaviest, strongest one you can find. You may regret spending the money on it later, simply because you won't know better. If you buy less, you will soon find out why you should have bought the more expensive one, and why they are more expensive.
David from jax
David from jax
