birdlover,
Not aware of any front PTO option on a Grand L30 tractor, but mid PTO to drive front implements is an option. This can be a very easy job to a difficult one depending on if your tractor was equipped with the necessary internal gear or not. If it has the internal gear the mid PTO cassette can be added where the existing block off plate is located mid-tractor. If the internal gear was not installed from the factory the tractor needs to be split to gain access.
I was lucky on my tractor and only the mid PTO cassette was needed. Drain hydraulic fluid, remove block-off plate, install mid PTO cassette, install linkage along with interlock switches and refill with hydraulics.
Here's what I found in an archive thread from 2009:
It looks like the Mid PTO kits are still available from Kubota for
L4330 - 43.2 HP - PTO Kit Number L8313
L4630 - 47.2 HP - PTO Kit Number L8313
L5030 - 52.2 HP - PTO Kit Number L8314
GST and DT ROPS Models require the L8315 Internal Gear Kit, as well
I believe the front snowblower I have was purchased used from an L4630 owner. Sorry, but I don't have any pictures.
Good luck and lets us know what you do.
