Ditto with the recomendation about getting yourself a good timer.
I dont know if you have domestic range equipment or in the semi pro range but I'll give my 2c worth anyway...
I use timers in the domestic range.
I'm on my third timer having tried several manufacturers. I started off with a "Gardena T14" digital display timer and after the first season it started to malfunction.
Gardena T14...
Either staying on constantly or not working at all. I changed the faulty one for a replacement T14 under warranty and you guessed it, the next year, after a while we had the same problems.
The following year I bought a more basic "Claber Pratico" which worked perfect for about 4 years but started to misbehave recently.
Claber Pratico...
This year I have a "Hozelock Aqua Control Pro" which has the added benefit of a rain sensor.
Hozelock Aqua Control Pro...
So far its working perfectly but time will tell how good it is.
Since we fitted the drip irrigation system, it has saved us a lot of money. No more dead plants. I have it feeding all of our potted plants, hanging baskets, window boxes and all of the flower beds. In all about 150-200 plants. My wife and I have hectic work schedules which gives us little time for watering plants. The micro drip system allows us to have a lovely garden with minimum effort.
In your situation for a productive garden, asthetics is probably not a big concern, the best advice is to make sure you protect your water pipes from sun or animal damage by burying it under mulch or a fabric weed barrier. Also pay attention to the instructions that come with your kit. It will recommend the number of feeds you can run off each main pipe line and recommend the nozzles to suit your application... litre per min and flow etc.
In my case, I had the most fun hiding the pipes around my garden and home. I spent an extraordinary amount of time and effort making sure water feed pipes would not be visible at all. The only place you can see the pipes are where they are feeding my hanging baskets. A 6mm tube running down one of the chains going to each basket. Everything else is concealed - buried under mulch, under decks, behind gutters or even above soffits in some cases.
A bit of forward planning made a big difference to me.
