Monster5601
Platinum Member
On the topic of mileage, why do the on board computers calculate the milage wrong. In the 5.7l hemi, screen says 19.2 mpg or so for last 3 fill up, but real mileage has been 17, 17.04, and 17.8 mpg. Not complaining about mileage, just wondering. Does the computer not count idle fuel use?
I assume you are using your average MPG numbers. Reset your average MPG at each fill-up (or use one of the trip meters) since the average is calculate over time and not between fill-ups. There has been a lot of flack about how average MPG are calculated, so much so, newer vehicles are starting to use average MPG over the last 50 miles traveled.
Each time you fill-up there is no way to tell how close to full you are or if you filled up to the same level as last time. Temperature of fuel determines the expansion of the gasoline, about 1% for each 12 degrees F, the warmer the gasoline, the more used to do the same amount of work. Also the amount of energy in the fuel you bought, some blends use more or less ethanol than others. While each of these (and other factors) don't add up to much, they are accumulative and impact the average MPG over time.
I have a 2013 RAM (5.7 L Hemi) that replaced my 2003 Tahoe (5.3L) and both vehicle's average MPG aligned with my hand calculations. I did reset the averages on both vehicle around the time our area switched between summer/winter blends because of the significant change in MPG between the two blends.
