puckgrinder85
Platinum Member
Mine too, a rod connected to the top part of the chute slides through a washer on the bottom part of the chute and the spring rides on the rod to keep it in alignment.
Jim, your idea about the threaded rod and nut sounds good in theory. You would have to mount the nut on a pivot so that the rod would not bind in it as its position changes. (The motor end should also pivot.) The speed would depend on the motor's RPM and threads per inch on the rod and nut. You may need to protect the rod and nut (motor, too) from ice and snow buildup. You are building a linear actuator!
