If you had a short somewhere I would think (hope) a fuse would blow somewhere.
Nov 8, 2012 / Electrical problem #11 mjw357 Platinum Member Joined Jan 30, 2011 Messages 706 Location The Sticks, Ohio Tractor Kubota B3200 If you had a short somewhere I would think (hope) a fuse would blow somewhere.
Nov 8, 2012 / Electrical problem #12 chim Elite Member Joined Apr 7, 2002 Messages 3,653 Location Lancaster County, PA Tractor Kubota L4240, Ford 1210 The first thing I'd suspect is dying batteries. The next thing would be poor connections. Corroded or loose connections can play havoc.
Nov 8, 2012 / Electrical problem #13 wdchyd Elite Member Joined Apr 16, 2010 Messages 3,350 Location Hooksett, NH Tractor Kubota B2320 If you don't already have one , these are a life-saver...... Battery Tester - Save on this 6v/12v Battery Load Tester You can test battery, charging system all within seconds.......One quicky repair will pay for itself alone.....You need the one with the built-in load switch (100 amp) I've seen local auto parts stores have them for 40 to 50 bucks too
Nov 8, 2012 / Electrical problem Thread Starter #14 OP M mtnsmith New member Joined Nov 7, 2012 Messages 13 Location Marietta, GA Tractor 1993 B2150D Thanks for a very good suggestion. I may have to get one of these.
Nov 8, 2012 / Electrical problem Thread Starter #15 OP M mtnsmith New member Joined Nov 7, 2012 Messages 13 Location Marietta, GA Tractor 1993 B2150D I will check battery first, then connections. Thanks.
