Farmwithjunk
Super Member
As already mentioned, most likely electraulisys. (sp) Wet sleeve diesels will eat holes in the cylinder sleeves. A combination of coolant system cavitation, acidic coolant (from age) , small dirt particles in coolant, and time will cause sleeves to end up with holes that look almost like someone took a cutting torch and burnt small holes into them. Coolant dumps into oil pan.....engines over-heat, bearings gald, you spend major coin.
Coolant systems on wet sleeve diesel engines require additional care. Coolant needs a treatment to maintain ph levels, and reduce cavitation. Many engine manufacturers have integral coolant filter systems on newer tractor, and also offer retro-fit filter kits for older models.
I once saw a John Deere 830 (3-cyl diesel, 35 hp, from early 1970's) with less than 400 hours with ALL the coolant in the oil pan from this malady. Not at all UNcommon.
