OP
Threepoint
Veteran Member
- Joined
- Feb 13, 2014
- Messages
- 2,238
- Location
- No. VA
- Tractor
- Kubota B2150HST w/ LA350 loader, Kubota GF1800 HST, Kioti CK3510SE HST w/ KL4030 loader, Kioti NX4510HST/cab w/ KL6010 loader
[snip]
One small nitpick here: RPM means Revolutions Per Minute. It is already plural. There is no such thing as RPMS. Putting an S after RPM would mean that "RPM" was a singular event that had to be made plural. A revolution is singular. Revolutions per minute, is plural. RPMs means you are discussing various engine speeds, not a particular engine speed. Such as: "What are the two different RPMs you like to run your tractor at while plowing or discing?"
Ha! A nitpick, maybe, but you raise another very interesting technical point. You've highlighted how linguistic awkwardness can come from strict adherence to rules of grammar. Especially when it comes to acronyms.
Consider the sentence: "When you have several gear ratios to choose from, engine revolutions per minute don't matter as much."
If I instead substitute the acronym, but strictly follow the rule of grammar on singular vs. plural verb form following a plural noun, the sentence becomes: "When you have several gear ratios to choose from, engine RPM don't matter as much."
Now, I myself am fine with the second construction. However, I'm pretty sure that Ms. Holcomb, my 12th grade English teacher, would have told me to switch to the singular form of the verb and say "...RPM doesn't matter as much". :laughing:
So, if the rule in that instance is honored in its breach, I don't see why we can't all just add an "s" to RPM where it sounds better, and call it good. That way we don't have to use the wrong form of the verb. We can just say "...RPMs don't matter as much." :dance1:
