Gentlemen,
I have a McCormick Farmall 140 (ser # 63353 JHC) that has been in our family since new. 1001 hrs. Always stored in a garage or a lean to. Never had to twist a wrench on it until 2 days ago. Figured I would get it running & sell it, since it is not needed on the "plantation" anymore.
It has been 10 or so years since it last ran. It was up to me to bring her out of its deep sleep. Purchased a battery. Pulled the fuel & air system (tank, lines, sediment bowl, carb and air box) and gave it a through cleaning. Regasketed the carb and sediment bowl (marvel schebler TSX864 77Y) and reassambled with fresh gas.
IT fired right up. Idled beautifully for about 7 seconds. Then started sputtering like the choke was on (it was not). Pulled the air cleaner assy and noticed some fuel was running out of the mouth of the carb (air filter side) when the motor would quit. This lead me to believe I have too much fuel flowing somewhere.
Pulled the carb and adjusted the floats to 1/4" from the gasket surface. Same issue as above.
Purchased a rebuild kit from NAPA. Could not find a kit for the TSX864. Used something close. (NAPA 2-1403). Replaced the Needle & seat & idle adjusting needle. Checked the float. This carb is a "type A" carb. "Fixed Jet" they call it. No external adjustments other than the above 2 items. Again I cleaned the carb. This time I noticed the power jet, located under the main nozzle. I could not get this jet out. I even broke a piece off of the top of the jet trying to. Should not effect operation unless A. it is still clogged and B. if the main nozzle seats upon the power jet.
Assembled everything but left off the air cleaner so I could view into the carb. Started right up (idle) but in a couple seconds the same issue, too much fuel again. I tried adjusting the idle adjusting needle (it was set at 2 turns out. Instructions said 1 turn which I was at) in & out. nothing made any change in the way it ran. Still too much fuel (in my estimation).
So I thought, ok, I will just replace the carb. Of course I could not find a listing for a TSX864 or a listing for a suitable replacement.
I am at my wits end guys. Hopefully someone can shed some light on my issue(s)!!
Thanks in advance!!
Thanks in advance!!
