seriousfreedom
- Joined
- Sep 16, 2011
- Messages
- 49
- Tractor
- kubota L3200; john deere lt190
check and see if there is a hole in the screw that holds the fuel bowl on i know if those are clogged up they wont run for some reason
will run on start fluid only..I am leaning to intake gasket leak
cleaned all ports with carb cleaner and air pressure..
No comp test yet..has plenty exhaust pressure..
Was running last summer..got water in the carb over winter so had to clean all out..
wil try some wire through all the ports
last year would only run on almost full choke only so I am still thinking intake leak
