Farmall Super M
   / Farmall Super M
Well I couldn't get the engine to move an inch. This was by hand but usually you can get something if they are free. Exhaust has been open. Out of respect I covered it. They are going to start cleaning up the place and will have to do something with it. Dunno if I want another fix er upper. We'll see.
Thanks,
Rob
   / Farmall Super M #32
Rob,
You should be able to sell that machine, running or not. I sold one this winter, a 1950 Farmall M with terrible rubber, dented and dented tin, lots of oil leaks, no 3PH, no electrical system, and a bad head gasket (but she ran) for $800, and the seller felt like he got a bargain. It had sat for 2 years and the engine seemed stuck, but my buddy got it loose for me.
I'm trying to sell a second M in better shape that has a loader rigged for plowing snow.
The guys at this site
http://snipurl.com/20ta2 [www_ytmag_com]
can help you quite a lot, even if all you want to do is sell it as-is or part it out on Ebay. Like TBN, you can post "help me" questions. I bet if you describe the machine and ask if they think it's worth trying to salvage, you'll get helpful replies.
If memory serves, IH made about 250,000 Ms from 1939 until 1951 or so. Lots of 'em are still running and all of 'em need a supply of parts!
Have fun!
Mackinac Joe
   / Farmall Super M #33
Well.....what did you do?? Do you have the M or is it still sitting???This thread is very interesting and I'd hate to see it fade to black the way it has in the last few days....BobG in VA
   / Farmall Super M
No change. If they give it then I'll drag it over to my place. I don't think I'm going to buy it. I have enough to do!! But they are going to start clearing the place shortly, so a decision will have to be made.
Rob
   / Farmall Super M #35
sometimes that works.
i know a guy that found an old 8n in somebodies front yard.. bad rubber.. no battery... He took a chance and walked up to the house to ask the owner if he wanted to sell it... Heck.. owner said he'd pay 50$ to have it hauled off! Guy came back and winched it on a trailer.. took it home slapped an old 6v battery in it and put some gas in it and it RAN! go figure!
soundguy
   / Farmall Super M #36
Hey Rob --- what a score!!! Heck, ya' can't even buy a pair of those fancy basketball sneakers for less than a $150!
Got room --- got kids? When you get around to gettin' it goin' yur kids are likely to come wanderin' around and watchin' what yur doin'...
Who knows; maybe they'll beat on it, too! (Hand 'em a wrench!) Learn some good words, too?!?
I'm no old tractor genius (or ANY tractor genius...) but I've never seen a SuperM that was a gas tractor.
They were diesel as I recall. One of the fellows up here has a beautifully restored M and a SuperM that they roll in the Fourth of July parade and use for hay every year.
The SuperM is a dual fuel starter... that is you start it on gas and after it's running you switch it over to diesel.
Anybody familiar with that??
AKfish
   / Farmall Super M #37
AKfish said:
Hey Rob ---
AKfish
There was a Super M which was gas only, and then there was an MD (or diesel). Not sure if they ever made a Super MD though...They did make a few Super MTAs...basically this gave you a 1/2 gear more in each gear. It was a lever than changed the gear ratio in the rear end if you were getting ready to bog down you could pull the TA lever and keep on going as (instead of say...3rd gear..)you would then be in what would be sort of 2 1/2 gear...BobG in VA
   / Farmall Super M #38
TractorData has the specs for the Super MD
TractorData.com - Farmall Super MD tractor data
In 1954 you could get a Super MD with a Torque Amplifier (Super MD-TA). The Super MD was pretty powerful (42 hp drawbar).
   / Farmall Super M #39
Thanks. OK... the "D" --- duh... I've used that site before to look up specs --- just lazy, I guess.
Still curious about the fuel, though.
I'm pretty sure when I was lookin' at the tractor last summer (pickin' up bales in the field) that it fired up on gas and then switched over to diesel after it was runnin'.
Wonderin' if that was IH's answer for the problems of startin' those higher torque diesels with the puny batteries and starters they had during those early years.
I remember reading about Deere's early problems with the big, 2-cylinder diesels and not wanting to go to 24 volt systems they developed the pony motor system to get 'em fired up!
(A little off track from Rob's "project" -- but good to kick around.)
AKfish
   / Farmall Super M #40
AKfish
Yeah, they did start on gasoline and once the engine was hot enough, you cut off the gas and turned on the diesel/distillate. As far as pony motors are concerned CAT used ponies on most of their bigger tractors for a bunch of years (older), as a D8 with a high compression 6 cyl diesel was pretty hard to turn over with any battery---then or now. I ran a D7 when I was 19 (If i remember correctly that track was a mid '60s) that used a pony....BobG in VA
