Don't confuse flow and pressure.
And "flow pressure" is not a term.
Pressure is where the strength comes from. 2000psi and your old loader was 2300, that will cost you a little bit of lift capacity, but shouldn't effect speed.
Flow is speed.
I suppose something could be wrong with the new valve. But there are a lot more things you can check. For those of us trying to help, you really aren't doing us any favors here giving small bits of information at a time and all broke up. Either call a mechanic, or do some basic troubleshooting.....ie the following
First, does it also lower slow? What about float detent?does it work?
Is this a new problem? Or is it a new to you tractor that you don't know the history.
"Fast" and "slow" are relative and mean nothing. Need data. How many seconds does it take to full raise at Max rpm? At idle? How long to lower? How do these times compare to when the hoses are hooked to curl side? Does float work? Will the loader raise the front of the tractor?
Have you pulled a hose off one of the cylinders, hold in a clean bucket, and hit the lever? Does flow seem good? How's that compare to a curl hose?
