/pine
Super Star Member
- Joined
- Mar 4, 2009
- Messages
- 15,059
just curious...is the metal going down on sleepers? Or is it laying directly on the underlayment ?
Anytime there is a quick change in temperature metal roofs will cause condensation...just curious how this is addressed?
in FL, where there is high humidity...if a solid decked roof (formerly shingel/tile etc) is being replaced with metal...a water proof base sheet (felt will work but becomes brittle) is applied with (usually) 1x4 pt boards run perpendicular to the metal on top of the base sheet...often there are weep vents cut into the 1x4's...the metal is then pre-drilled for screwing down to the 1x4's.
It is not uncommon on cold mornings that warm up quickly for moisture to be seen running from the weep holes in the bottom edge 1x4s...I can imagine what happens to that moisture if there is no way for it to escape...
