joshuabardwell
Elite Member
The problem with guesstimating based on volume is that most humans are very bad at estimating volume, especially of irregular shapes. If you must estimate based on volume, I suggest measuring the object and approximating to a regular shape (e.g. a sphere, cube, cylinder, so forth) and then using geometric formulae to calculate the volume. This will likely get you in the ballpark, assuming your density assumptions hold.
If you need to measure density, take a sample of the object (e.g. by chipping of a chunk of the rock or something), measure its weight using a scale, then submerge it in water and determine the volume of water displaced to get its volume. Density = weight / volume.
