scoutcub
Veteran Member
- Joined
- Aug 19, 2008
- Messages
- 2,406
- Location
- Ohio
- Tractor
- Yanmar LX4900//Cub 7532//Cub Yanmar SC2400//Komatsu D38//Cub Volunteer//Cub SZ60/CAT 289C/CAT 308
most turbo failures are due to being shut down without cool down ( idle for XXX minutes ) the turbo shaft is run thru the center bearings that are oil cooled ( hot exhaust one side , fresh air being compressed on the other side of the snail ... both get really hot ) ... shutting down without idling allows the heat from the shaft to migrate to the bearings , but the engine is off and there is no oil cooling to take the heat away .... so the oil in the bearings gets cooked and gums up the bearings ... eventually the bearings seize and the turbo won't spin up...
idling allows things to cool off ......
extended idling wastes fuel and can coke up some turbos .
VNT turbos ( variable vane ) sometimes fail from coking up the internal mechanisms ( extended idling ) .... so the turbo lessons are :
1 warm up the engine a bit before putting a load to it
2 let the engine idle a bit to cool things down if you were on the turbo
3 some turbos have a period of lag (time to spin up) after you hit the pedal ....
4 turbos can be more efficient and produce more power out of a smaller engine ...
5 turbos are expensive when they go/fail ....
treat your machines properly and they will last a long time ,,,, treat them badly and they will be more expensive than that last divorce .....
I would agree with this observation. I have 5 Turbos.....2 on tractors, one on a dozer, excavator, and my F350. For the equipment, most noticeable when a load is applied and you get the extra "oomph" when the rpm's are up...:thumbsup:
I've never had a problem with turbo's except the one on a Saab 900 many many years ago....not sure why I even bought that car....:confused3::laughing:
